driving/ fog light questions
Old Dec 7, 2006 | 10:44 AM
SoCalBlue's Avatar
i am planning on installing some fog lights in the bumper opening. not sure which lights I'm going to go w/ but my main question is about wiring. I would like the fogs to turn on with the headlights thus negating the need to cut a hole for a switch. what is the easiest way I can do that? any help is much appreciated.
Old Dec 7, 2006 | 11:40 AM
Inline6's Avatar
The lamp kit will come with a wiring schematic. Instead of wiring the hot lead from a keyed power source through the switch, use a lead off your headlight switch or somewhere in the harness such as off the headlight. You will either need the Ford wiring schematic or play with circuit tester to get the correct wire(s) to tap into. You could also just find a keyed power source and have the lights on whenever the key is on, just tell the cops its your DRLs...
