fumoto valve question
Old Dec 5, 2006 | 08:21 PM
straggleweed's Avatar
ive over tightend the plug on my oil pan too many times now and the threads about gone near the head of the bolt... so how reliable are the fomoto valves can something hit it and cause it to open while driving, i know it will make changing the oil much easier but i just dont want it to come open when im not ready for it to
Old Dec 5, 2006 | 08:24 PM
Rockpick's Avatar
Moderator &
Could something strike it and cause a failure? Yes. But, I think the odds of that are next to nil.
I'm running one on my truck and also one on my wife's 04' Explorer.
I originally bought one for my wife's because the boneheads at the stealership over-tightend her's and stripped it ever so slightly. As a result of that strip, I had a VERY annoying tiny drip on occasion -- just enough to stain the garage floor which really burned my bubble.
To remedy this - rather than getting a replacement plug or going back to the dealership to plea my case 4k miles later - I went with this device. I'll have one on EVERY vehicle I own from here forward...
For those of you wondering about this dohicky...
www.fumotovalve.com
RP
Old Dec 6, 2006 | 12:52 AM
KSpencer's Avatar
You can get slightly oversized drain plug for the pan. I would get one and stop overtightening the plug.
Old Dec 6, 2006 | 10:21 PM
Neil's Avatar
25 Year Member
I've had a Fumoto on my 2000 F250 for about 6 years, and I had one on my 2001 SuperCrew. When the Screw got wrecked, I took the Fumoto out and installed it on my 2004 Screw. I have not had any problems, and I can't say I've ever heard of anyone having trouble with them.
You'll find the Fumoto valve on A LOT of the over the road big rigs. Those fellas put on hundreds of thousands of miles over the years, and I'm sure that they run over their fair share of junk on the road. I spent 14 years wrenching on the OTR trucks, saw lots of those valves, and never saw one dripping.
I can't swear to it, but I think they may use the Fumoto on small air plane engines...can anyone confirm that??
Buy one, you'll love it! OH and if you are afraid that it might open by itself, buy yourself a bag of the 4 inch nylon ties at the hardware store. Wrap one around the groove that the lever slides in. With the tie in place, the lever can not be lifted out of the recessed area.
Old Dec 7, 2006 | 12:01 AM
thanks for the advice ill probably get one in a week or two. it seems like im changing the oil every three weeks, since i drive so much goin to school
i think im sold on it now that neil said the wire tie idea
Old Dec 7, 2006 | 12:56 AM
jsb's Avatar
jsb
Thumbs up If your worried about the Valve opening - do what I did....
If your worried about the Valve opening while driving, do what I did:
Get this:
And attach it like this:
Full info here:
http://www.fumotousa.com/faq.htm
And I couldn't find those specific clips locally, so I bought them from here:
http://www.lubricationspecialist.com...tml=fumoto.htm
Oh, and I bought the F106N (with the nipple). Then I went to NAPA and found Vacuum Caps 3/8" in size to cap the nipple end of the Fumoto Valve. NAPA part # 715-1805. So no dirt can get into nipple opening end. And with a short piece of 3/8" Inside diameter hose I can drain my oil directly into the recycle container. Installed it all about two weeks ago, and now am actually looking forward to my next oil change.
JSB
Old Dec 7, 2006 | 04:00 PM
Rockpick's Avatar
Moderator &
Nice suggestion JSB...
I may give that a go on mine... I bought the one that you can attach a piece of hose to (simply for ease in hitting my drain pan because I always seemed to make a mess when doing it the 'old fashioned' way'...
RP
Old Dec 8, 2006 | 12:08 PM
Flyin'Hawaiian's Avatar
Is the #F-106 the correct one for the 5.4-3V? Thanks.
Old Dec 8, 2006 | 01:00 PM
tx-import's Avatar
JSB - can you get pics of your set up?
Great ideas guys I was cursing the other day dropped the plug and the wind blew at same time thus missing the drain pan.
Flyin Jawain, F-106 is the correct part number for the 5.4 L engine and F-106 N if you want the nippled version
Old Dec 8, 2006 | 03:03 PM
jsb's Avatar
jsb
Yes, I'll take some pictures this weekend
Yes, I will take some pictures this weekend.
JSB
Old Dec 9, 2006 | 10:43 AM
Mahalo!
Old Dec 9, 2006 | 06:17 PM
jsb's Avatar
jsb
Here's the picture
Here's the picture of the items before installation. I think you get the idea.
JSB
Old Dec 11, 2006 | 11:09 AM
tx-import's Avatar
Thanks, I can visually see the set up now. Thanks for your time.
Flyin-Hawain- You welcome...:santa:
Old Dec 11, 2006 | 11:29 AM
cvc14's Avatar
Is this the right item...
http://www.f150store.com/Shop/ViewPr...&PlateTypeID=1
Old Dec 11, 2006 | 11:31 AM
cvc14's Avatar
JSB
How do u hook the hose up to it.. does not look like it has a nipple on it or anything for the house to slide onto.. Maybe its just the picture not showing it.
