ac compressor???
Old Dec 1, 2006 | 03:36 PM
jmt0645's Avatar
Exclamation ac compressor???
what wire is the positive on the AC compressor plug 'cause I'm trying to install E-fans but ran into a snag. thanks
Old Dec 1, 2006 | 05:51 PM
jmt0645's Avatar
Old Dec 1, 2006 | 07:31 PM
stevenslow's Avatar
I'm running mine to the gray/white wire under the relay box on the left fender. There is 2 that are the same color, but I checked with a volt meter and must have gotten lucky. If you figure out where to mount the controllers, you can help me out
Old Dec 1, 2006 | 07:37 PM
bushtree's Avatar
do a search and you will find the information.. I know its on these forums somewhere becuase thats how i found it..
But as i remeber theres a connector that plugs into side of the AC compressor. Unplug that connector. That wire is covered in wireloom, so you need to cut a couple of inches back to get access to the wires. There are 2 wires under that wire loom. Its 1 of those 2 wires.. But i cant remeber which one
