Best Edge Settings, For Best 0-60 Time????
Old Dec 1, 2006 | 12:44 AM
weazel's Avatar
Registered User
ok, i have tried a couple of setups and my fastest it 7.94 0-60!
my settings are level 3
-Shift Firmness: 1-2: +4, 2-3: +4, 3-4: 4
-Timing: +1.00 (91 octane plus above sea level)
-WOT Shifting: 1-2: 5200, 2-3: 5200, 3-4: 4900
-STD Shifting: Stock
-Rev Limiter: 5600
-WOT Fuel: 1.70
Can some one chime in a help me out? i tried uping my WOT Shifting and it made it worse, seems like theres no power up there........
Old Dec 1, 2006 | 01:12 AM
zachespo's Avatar
I think that is actually pretty good considering that you have 35" tall tires with the 4.56gears.
The best i was able to run was a 7.4 but i don think that the road I was doing it on was completly level becuase i pulled a 7.4 off one way and the other way I was only able to get about a 7.8s 0-60 time. I guss ill have to find a better road. But it wasnt in exactly the same place so I will have to find a better spot or something.
And those times are on 33s with 3.55 gears.
Old Dec 1, 2006 | 01:56 AM
weazel's Avatar
Registered User
what do you have for your settings, i want to see if it helps me....im trying to hit 7.7-7.8
Old Jan 4, 2007 | 06:35 PM
Neuby77's Avatar
I have all my shifts set to +8, my timing bumped up .5 on level 3 with 93 octane and my best time is 7.6... that with 3.55's in a 06 crew cab. I would think that with your gearing that you should be pulling harder than me even with the 35's???
Old Jan 4, 2007 | 06:51 PM
weazel's Avatar
Registered User
can you give me a detailed list of ur setting please..
Old Jan 4, 2007 | 06:56 PM
zachespo's Avatar
Even with his gearing turning those tires takes a lot of torque so even though the gears seem low it takes so much more to turn the 35's than stockers. Not to mention the fact that its way up in the air so aerodynamics are crap.
Also you could up your timing to +1.00 no problem and posibly even higher to get a better time.
Old Jan 4, 2007 | 10:36 PM
Neuby77's Avatar
I have the level 3 program set, the only adjustments I made were
3.55 gears
1/2 shift +8 (firmness)
2/3 shift +8
3/4 shift +8 (try this setting once, it really doesn't feel harsh at all, just a nice solid shift when you're getting on it, otherwise just driving normal I barely notice it).
Timing +.25 (also using 93 octane fuel)
Tires adjusted for the factory 20's
Other than that, I haven't messed with anything else. My truck is a 06 4x4 loaded Lariet screw, so you know it's a HEAVY pig! Have you tried adjusting level 2 instead of 3? People are saying that it has more low end grunt than level 3 which I would think would be better for you if you are trying for a good 0-60 with those torque sucking 35's... just a thought
Old Jan 4, 2007 | 10:48 PM
weazel's Avatar
Registered User
3.55 gears
2/3 shift +8
thank you for the write up.....yeah i tried level 2 did better on 3!
Old Jan 5, 2007 | 12:03 AM
alex_pitts87's Avatar
now i have my gears at 3.73 and my tires are set perfectly and i run a consistent 6.9 0-60 and i have about the same settings as all iof you guys
i guess my truc just hauls...
Old Jan 5, 2007 | 12:18 AM
weazel's Avatar
Registered User
list your settings out! a detialed list please
Old Jan 5, 2007 | 06:44 AM
Neuby77's Avatar
Your truck is shorter than mine, not sure how much lighter it must be. Looks as though you also have an exhaust and intake, I wonder how much those are helping? Still, that's a great 0-60
