Dust behind gauge cluster?
I've searched through all the cluster threads and didn't see any good instructions for removing the cluster from an 05 F-150. I need to remove it, so I can clean the dust from inside the cluster lens. Somehow ended up with a dust streak on the inside and its driving me nuts.
Thanks!
Thanks!
Remove two bolts from the bottom of the panel that is in front of your knees, then pop the top of the panel off, then remove one bolt from the right and left hand corners of the bottom of the cluster surround, tilt the wheel all the way down, and then pop the cluster suround off..
