Help with Headlamp adjustment!
Old Nov 5, 2006 | 12:11 AM
EMTDS28's Avatar
Can anybody help me out? I put a leveling kit on my F150, now everybody thinks I have my high beams on all the time!!! Can anybody give me a quick hint on how to adjust my lamps lower? Thanks!
Old Nov 5, 2006 | 12:21 AM
BalogUK's Avatar
you need a 4mm socket or the ford headlamp adjustment tool- you only have vertical adjustment.. when you look down at the top of the headlight, (hood open) you will see a 3/4" inch long hex stud- that is the piece you need to rotate. your manual has aiming specs to get them correct
Old Nov 5, 2006 | 01:22 AM
styxnpicks's Avatar
just flash your brights back at em
Old Nov 5, 2006 | 01:23 AM
HIDPLANET's Avatar
RTFM
Old Nov 5, 2006 | 01:29 AM
BalogUK's Avatar
Originally Posted by HIDPLANET
RTFM
so friendly this saturday night...
ive got a 2.5" as and 35" tires got flashed seemingly every night... never adjusted them... bought harley lights, haven't been adjusted, and haven't been flashed once...
Old Nov 5, 2006 | 02:13 AM
keith61760's Avatar
I put Silverstars in and no nobody flashes me about brights.
Old Nov 5, 2006 | 02:27 AM
Nates06SCab's Avatar
I put tape lines on the garage door after the leveling kit. I lowered the top edge of the "hot spot" the same as my actual lift. Three inches. I've only been flashed once since then (post Silverstars). I didn't mess with the fogs. I used a socket that fit the aiming bolt, and pliers to turn it. That's what I needed to get it done.
Old Nov 5, 2006 | 04:26 PM
EMTDS28's Avatar
Thanks everybody for the help and input! Other than the RTFM guy I'll let everybody know how it goes. Thanks again!
Old Nov 8, 2006 | 06:20 PM
EMTDS28's Avatar
Thanks again for the hints. Adjusted them the other day and didn't get flashed once on the drive home!
