Question about keyless entry
passive anti-theft system (the red blinking light on your dash), encoded keys
yes, with another encoded key you will be able to get remote start, remote entry, and if you buy one with an alarm, you'll have an alarm
that red light is to deter would-be thieves from your truck by making it look like it has an alarm... its not an alarm.hence Passive... the second line of defense is the encoded key- you insert a non-encoded key, and the starter locks
the light has nothing to do with the key... that little bubble is also the daylight sensor for the automatic headlights
but, you can have either the ford aftermarket security package installed, which is an alarm, or you can put in your own
Originally Posted by JNC995
So, do you really need an alarm if they cant start your truck without the encoded key?
Originally Posted by bluejay432000
Then they tell you they will remove it if you don't want it. Well, I did not want a truck that had one installed and then had it removed, so I paid for it. Neat way to increase your add on by the dealer.
The alarms the dealers put in are usually put in by a local cheap shop, not the dealer.
The wiring, install, etc. on the one I had removed looked like they had been done by an illegal on his first day in the country.
So I fixed his mistakes and tidied up the wiring.
Later I put in a Ford Deluxe Alarm, a very simple install.
Those dealer markup things are a true rip-off.
Chris
