2006 fx4 trans question
Old Nov 1, 2006 | 09:04 PM
icemoose31's Avatar
Ok,
I will be the first one to admit i know nothing about automatic transmissions, i know manuals and sequentials. so excuse my what may be simplistic question.
I have a 2006 scab fx4. i have 7k miles on it. Ive always felt like the trans slips a lot, i took it to the dealer, they said something was definatley wrong with it, and then called me back the next day and said everything was fine. This week my father bought the same truck, hes is no where as bad as mine. Then today i notice, i back up my drive way, probably a 20 degree slope from horizantal, and i take my foot of the brake, and my truck rolls down the drive way, still in reverse mind you. So i pull out, pull into the drive, check it, and the truck rolls backwards down the drive way.
I pull my dads truck out, try his, it stops, doesnt roll at all.
So my question is, should an auto trans roll down a hill in gear, if the gear is in an apposite direction that it rolls?
Please help, im tired of getting 8 mpg and having no acceleration.
(also posted in transmission forum for more help)
Old Nov 1, 2006 | 09:19 PM
deerfeedrb's Avatar
My first thought would be to check the transmission fluid level; if it's low, then it will slip like you have described.. I'm not sure other than that.
Old Nov 1, 2006 | 09:42 PM
GotBeer's Avatar
Rolling down the hill is completely normal, but a slipping transmission is not. Keep taking it back to the dealer till they fix it for you.
