Rim Painting
Old Nov 1, 2006 | 02:52 PM
pachi7tre's Avatar
Rim Painting
Dont laugh, I'm very bad at trying to modify pictures. This is the look i'm going for. I want to powder coat the black area's. I think it will look great. If someone could photoshop the pic for me a lilttle better it will be great.
My attempt
Clean pic for photoshop use.
Thanks guys. I got these off of ebay $1100
Old Nov 1, 2006 | 07:21 PM
blackfifty06's Avatar
I think that would be a good idea. What color is your truck? Good Luck.
Old Nov 1, 2006 | 08:19 PM
pachi7tre's Avatar
Black w/arizona beige strip.
Old Nov 1, 2006 | 08:57 PM
FoMoCoFan17's Avatar
Go for it. Looks good to me.
Old Nov 1, 2006 | 09:27 PM
texasmusic's Avatar
my 5 min photoshop job. I'd spray the tips of those bolts too but thats just me.
Old Nov 2, 2006 | 09:55 PM
pagan696's Avatar
10 minute quick mask...
Old Nov 2, 2006 | 10:04 PM
CANNONFX4's Avatar
Pagan, please tell me how you did that. I have been trying to improve my photoshop skills.
Old Nov 2, 2006 | 10:08 PM
ThumperMX113's Avatar
I wouldn't paint them anything other than arizona beige. . now if you had a monotone paint scheme than I'd say it'd be okay.
Old Nov 3, 2006 | 06:09 AM
pagan696's Avatar
step by step: (this also works with any of the more advanced image editors)
1- copy image from your post.
2- paste into new document, add a new layer for the color effects.
3- use ruler guides to guide where i want my circle mask paths to match up to, then i draw a circle i hit the rim edges very closely and fill with black (or desired color), then deselect the new color layer.
4- use the pen tool to click/drag to make the shape of the void areas from the color layer (basically everything that was within the black filled circles that i do not want colorized), make the paths a selection, then delete from the color layer.
5- once all of the color areas correct, then use the layer property "multiply" to allow the under image (your original) to bleed through the new color layer on top. i also reduced the opacity to show more of the highlights/shadows of the rim. as in this case w black, you can also select the new color image area, switch that selection back to the original image and brighten/contrast to give it more "pop" under the new heavier colored later.
6- if the edges look too sharp and jagged you can feather it to soften the edge so it's less noticable you've doctored it in photoshop.
7- post and enjoy!
i also have been using photoshop for a long time and it's a very powerful software tool. it takes doing little fun project like this to get a good feel for it. keep trying and if my post makes no sence, this weekend i'll try to post a better step by step and possibly links to more tips.
Old Nov 3, 2006 | 01:22 PM
CANNONFX4's Avatar
Thank you very much! I will try going through those steps and see if I can manage to get the same result!
Old Dec 22, 2006 | 08:06 PM
welfare wagon's Avatar
I have been thinking about doing the same thing with my 20' wheels painting the areas you have black with the Arizonia beige, I have already been looking in to it with a local paint shop, my only concern is just using auto paint basecoat/clearcoat could it chip and flake off if rocks hit the wheels or a scratch
Could someone photoshop the same wheels with an Arizonia Beige?
Old Dec 22, 2006 | 08:23 PM
1BDf-150's Avatar
$1100, man you got ripped off
Old Dec 22, 2006 | 09:31 PM
Boy you sure did, you can pick those up all day long for around $500-800 on ebay nowadays, even in chrome is cheaper then that.
Old Dec 23, 2006 | 10:02 PM
mkinttrim's Avatar
I painted the factory wheels like that on my old ranger. Make sure you rough up the areas you want to paint with a 400-500 grit paper and wipe it down with alcohol to get up any grease. I painted mine a satin black and went over it with 2 coats of clear. Never chipped afterwards. (3yrs)
I did it on a very hot day, took all 4 wheels off, sanded, masked, then wiped down. Sprayed all 4 wheels and layed them in the sun on top of a black piece of cardboard so it could collect the heat of the sun.
