Traction Bars for Lowered 2wd?
Hey guys, I have come to the conclusion that I am suffering from fairly severe axle hop. I do have a rear flip kit, and I have noticed it does NOT have shims.
I am trying to figure out the cheapest way to fix the problem. I believe I rear somewhere that adding shims should fix this?
and if not, does anyone know of any TRACTION BARs that would fit an application like mine? (2005 Lowered 2wd)
Here is a topic with the JLP Racing bars, but they fit a Lightning. From those pics it seems that 'type' of setup would fit and work on my truck as well.
Originally Posted by styxnpicks
I wish I could just 4 link mine with some coilovers
you could make your own traction bars, not too hard as long as you know how to weld
Altough I appreciate the comments and suggestions guys... I think most of you missed my KEY problem here... I have a REAR LEAF FLIP KIT... so no ordinary kit will fit, right?
And also, anyone know about the whole "shim" idea... does that really fix axle wrap?
and i dont think a shim would fix it, the only thing it would help is that so your ujoint doesnt bind up when the axel does twist. btw what kind of flip do you have? the djm doesnt require shims, it is adjustable. and most others have the shim made into the flip kit
I have the Grounf Force 9933 kit. I fraking ordered the 9944 (2/4, new leafs rather than flip) but they were on national backorder so I got stuck with thew 2/5 flip kit. Man the hassle that has turned out to be...sigh.
and I checked...no shims whatsoever in my kit. And I think I heard somewhere that GF has now started including shims with their flip kits.
dude since your in SD go to www.skgmotorsports.com and ask for elex (pronounced alex) and tell him ken sent you. he built my bars and are damn solid. if he can get a look at your truck im sure he'll figure osmething out
