cranking coilovers
Old Oct 26, 2006 | 02:31 PM
extremeethan's Avatar
cranking coilovers
does using preload on coilovers degrade the ride?? It is a stiffer/firmer ride? I decided on a coilover and UCA package and the coils can be cranked to gain some hight but I was wondering if it would ride better if I still used like a 2inch As then only crank like a half inch??
Old Oct 26, 2006 | 02:47 PM
BestNTx's Avatar
Yes... it will be a stiffer ride. It would deff be fine to use a 2 inch spacer on top and crank the coilovers if you are getting the total chaos UCA...
By the way which UCA and coilover did you choose?
Old Oct 26, 2006 | 10:15 PM
Total chaos UCA and the racerunner coilover. they are a set and the UCA come with the mounting kit for the racerunners rezzy. I have honestly had at least 6 people tell me not to lift it because it would just blend in with the all the others lifts. Has anyone else been told not to lift it because it looks good as is? Everyone has told me cool shocks would be wayy cooler then a lift that everyone has. I live in AZ and everytruck is lifted and they said it would look different not being lifited
Old Oct 26, 2006 | 10:17 PM
patshea098's Avatar
how much total? and how much are the UCA's and shocks seperate form eachother?
Old Oct 26, 2006 | 10:21 PM
850 coilover and 715 UCAs I have a guy buying my blsteins for 200 allready and then I also hope to sell my as for maybe 50 and then get a 2inch insted.
