2004-UP Stock Fuel Pump question.
Old Oct 23, 2006 | 12:27 PM
khendrix2374's Avatar
Why does it matter?
Every project that you say you want to build is over 500RWHP. The stock fuel pump is NOT good enough to support that much. Many members already found that out.
Why do you want to know so bad?
You will need a new fuel pump for your projects.
Old Oct 23, 2006 | 12:38 PM
rafa26's Avatar
Originally Posted by khendrix2374
Why does it matter?
Khendrix2374, everything you wrote above is known for a long time. Dustin Whipple said the stock pump(5.4 3V trucks only) is good for up to 500RWHP.
I think he is right because RoushMarkLT made 450RWHP already and he still had some room when he was on the dyno so i think the information about 500RWHP is accurate.
The reason i want to know this so bad it's because i am thinking about the possibility of installing 2 of those pumps .
Just think, Ford quality pumps, less custom work. That would turn into an easy install.
Thanks.
