front brake felt pulse when brakes
Old Oct 18, 2006 | 11:38 AM
YOMAN's Avatar
I have 2004 F150 Screw..
I replaced all 4 pads cuz of dust brakes that i m sick of it. I replaced it with portfields and then after a while i m starting feel very LIGHTY pulse/shake when brakes argh...guess stock with aftermarlet no good???
Any feedback???
Thanks!
YOMAN!
04 Screw
Old Oct 18, 2006 | 11:54 AM
05supercrew's Avatar
Did you cut the rotors?
Old Oct 18, 2006 | 12:06 PM
YOMAN's Avatar
Nope...am i suppose to do that ?? (bring it in for rotor to cut?)
YOMAN!
Old Oct 18, 2006 | 12:09 PM
YOMAN!
Not everyone does it but when you do new brakes you should cut your rotors so the pads sit properly. Pull the rotors off and have them cut, should only cost $15-20.
Old Oct 18, 2006 | 12:24 PM
BestNTx's Avatar
you mean having the rotars turned or slot cut?
Old Oct 18, 2006 | 12:30 PM
Monkey-1's Avatar
Turned.
Old Oct 18, 2006 | 12:49 PM
BestNTx's Avatar
Originally Posted by Monkey-1
Turned.
ok, yea always turn the rotars when changing pads
Old Oct 18, 2006 | 01:40 PM
YOMAN's Avatar
Oh i see...didnt know that ok, thanks..
One question, how long will stock rotors last ??
Do i need to turned all 4 rotors ???
YOMAN!
Old Oct 18, 2006 | 01:55 PM
YOMAN!
Only turn the rotors your doing the brakes on.
Old Oct 18, 2006 | 02:06 PM
ThumperMX113's Avatar
Sounds like warped rotors, turn them and see what happens.
Old Oct 18, 2006 | 03:29 PM
scottps's Avatar
There's a TSB on the 04 Rotors. Check with the dealer first...
Old Oct 18, 2006 | 03:37 PM
KSpencer's Avatar
Agreed. Turning rotors gets rid of the lines or grooves that accumulate after long pad wear. If the peddle pulsates, then the rotors are usually warped causing the pad to ride up and down. I would also check the TSBs for the 04's, then look into the rotors for being warped.
