Question on Adjusting Headlights????
Old Oct 15, 2006 | 01:29 PM
herrs04's Avatar
Just got a lift on my truck and when i drove it home a lot of people were flashing me thinkin i had my brights on. So how hard is it to adjust your headlights??I never even thought about having to adjust them!!
Old Oct 15, 2006 | 01:34 PM
mkinttrim's Avatar
Its a piece of cake, if I remember correctly there is 2 small square drive screws (rather long) on the headlight assembly, one for vertical and the other horizontal, might be a good time to change to some silverstars while you are in there!
Old Oct 15, 2006 | 01:37 PM
herrs04's Avatar
thanks for the help.. silverstars???
Old Oct 15, 2006 | 01:39 PM
mkinttrim's Avatar
H13st made by sylvania, alot brighter than stock bulbs! They'll really be flashing you then!
Old Oct 15, 2006 | 01:42 PM
herrs04's Avatar
Haha...Im sure they would like that..i'll put them in and keep my headlights where they are at!!
Old Oct 15, 2006 | 01:52 PM
BalogUK's Avatar
its a 4mm hex stud to adjust it you will most likely have to pull the headlight out some as its a pretty tight spot- im almost positive that there is only vertical adjustment on the f150s the horizontal should be fixed and non-adjustable...
Old Oct 15, 2006 | 01:54 PM
kingfish51's Avatar
You are right, only vertical adjustment on the 04 up.
Old Oct 15, 2006 | 02:34 PM
GotBeer's Avatar
Here is a little help for you: http://home.att.net/~borrani/articles/tech/aimhigh2.htm
Rockpick's Avatar
Moderator &
Edzachery. No other adjustments.
Old Oct 15, 2006 | 02:42 PM
kingfish51's Avatar
Originally Posted by GotBeer
It's also in the owners manual.
Old Oct 15, 2006 | 02:47 PM
Matt 05'FX4's Avatar
You don't have to remove the headlight to adjust it. It is designed to be aimed with it bolted in place, that's the way all headlights are designed, so they are aimed properly with it in the mounted position. You need a headlight aimer or follow the directions in the owners manual for aiming on a garage door.
Old Oct 15, 2006 | 02:56 PM
BalogUK's Avatar
100% correct- but if you dont have the tool- when i tried using pliars in place, it was looking to strip the hex, so to get the 4mm socket& wrench in I had to slide the headlight assy. out about a half inch- just sharing my experience
Old Oct 15, 2006 | 06:19 PM
Ahhh I see. Yeah they look like they are gonna strip right off when you do it....but mine turned finally
Old Oct 16, 2006 | 12:00 PM
Nates06SCab's Avatar
I put the 4mm socket on the adjustment screw, and then used pliers to turn it.
