tsb for injectors ?
Old Oct 3, 2006 | 11:04 AM
gotshot's Avatar
tsb for injectors ?
I know if it is not broken they cant fix it but I was wondering if there was a tsb for injectors? They just found one bad one on my truck and I am worried about others going bad. I think that if it is known the injectors are junk they should be replacing them all. Thanks.
Old Oct 3, 2006 | 11:16 AM
Quintin's Avatar
You would think that they should replace all the injectors, but unfortunately the dealer cannot do that. They can only fix what's broke, and if it's only one or two injectors out of eight, that's all they can replace.
Old Oct 3, 2006 | 12:02 PM
cndcowboy's Avatar
What are the symptoms of bad injectors?
Old Oct 3, 2006 | 12:05 PM
CraigH's Avatar
My truck didn't like to start after it sat for about 45 minutes or so. The injectors would leak causing the engine to flood.
they replaced 4 on my truck and I am afraid the others will go bad after the warranty is up.
Old Oct 3, 2006 | 12:29 PM
cndcowboy's Avatar
Thanks for the info. I wish you luck with the rest of your injectors.
Old Oct 3, 2006 | 12:31 PM
gotshot's Avatar
My truck developed an occasional stumble while sitting at a stoplight. I dont know yet if it was sticking open or closed or what. I did check on it at the dealers yesterday and it was running in the lot and it was a lot quiter so I am sure they replaced the cam phasers. Titus-Will in Tacoma.
