There has got to be a better way..
I want lift my truck and i've been lookin at these lift kits and i dont want to put that huge space on top of the strut. i would rather buy new coilovers with the spacer built in and adjustable. i'm havin trouble finding a kit that has them. the only one i saw is the skyjacker. and for the rear i wouldn't take out my two inch block and put in a 4". that's retarded. why wouldn't you just leave the stock block in and get an aal.
anyway let me get to the point. there has got to be a way to purshase the steering knuckles, sub-frames and a few other small components to lift my truck and use the coil-overs and the aal. it just seems sensless to spend $2000 on crap that i dont even want to use.
anyone ever thought about this?
Fabtech has the kit with coilovers like Josiah, I think Pro-Comp even has the coilover kit. What useless stuff are you refering to? The only other parts are the cross members and the hose extensions. I am pretty sure that everything in the kit is needed. Correct me if I am wrong.
ya know the guy with the dsg reg. cab who bent his his whole strut from the bolt on spacer? i'm just sayin i dont want that spacer i want coilovers and if you're payin for a 4" piece of metal that's gonna give you axle wrap then that's just retarded when you're half way there with your stock block you just need a $100 aal to get leveled with your front.
Some come with a 5" block like mine. Don't take any offense to this but I'm probably pushing more pony's to the floor than most and running rather large tires to boot...axle wrap has not been a problem whatsoever except under acceleration in sand (Chris had some ***** or a deep pocket out at pismo to keep pushing it while hopping like a pogo stick
). If it is a problem you can get a link system for the rear (ala Rize) to prevent and allow for better wheel travel too (pointless when you're 1/2 IFS anyway, my 37's tuck entirely into the fender wells as it sits). Truth is, you more than likely will have no trouble with a block lift...almost all kits do this but you can always purchase a PC or Skyjacker AAL. AAL amount to a stiffer ride (only advantage to a block lift) but they're better suited to handle axle wrap (if you're pushing decent power they can have their axle wrap problems as well).
No ***** or deep pockets here when it comes to "hopping it like a pogo stick." More like, EXTENDED WARRANTY!
I am gonna get the CST lift for our trucks as soon as I have the money, maybe after I get my tax refund if it's $10k like I hope it's gonna be. It should be pretty big. Anyway, that's really the only lift I will consider. I have done a LOT of research and sure it costs a lot of $$ but I think its worth it, being that it uses its own UCA's, etc...
i was thinkin about this today and i seriously doubt that the companies would charge you or put in a part that you don't need. i would think they are adding parts to strengthen the frame of the truck to withstand the added stress...
I am trying to find some traction bars for my truck. Sometimes I worry about my rear axle
i didn't say i didn't need the part. just didn't want spacers.
i've never had a problem with my spacers.
and I use my truck to its advantage! so don't be skerd.
every kit is going to come with something you don't want. If this is bugging you soooo much, then fab your own kit .....thats my .02
