Factory ride height on the Harleys?
Old Sep 25, 2006 | 11:15 AM
Muddyape's Avatar
Are the Harley editions with AWD (all of them of course) the same height as a 4x4? or do they sit a little lower? Obviously its got a front diff. etc like a 4x4 but I was wondering if their stance isnt slightly modified. The point is i'm thinking of buying some 22's from ebay and wondering how they'll sit on my 06Screw with a lowered rear end (no blocks) or if the tires are gonna be too small and i'll have to go aftermarket. Thanks.
Old Sep 25, 2006 | 12:04 PM
styxnpicks's Avatar
I'm running the same tire that the harley uses. altho I'm a little lower than the harley. they do sit lower tho
Old Sep 25, 2006 | 11:10 PM
robinerikd's Avatar
Yes, the HD versions ride 2" lower than the stock 4x4 setup on all four corners. If you removed your rear blocks (like I did) your rear end will be the same height as the HD but you front end will still be 2" higher. Did that make sense? I actually like the look of my truck being a little higher in the air. I think the Scab with 6.5' bed and a lowered stance makes the truck look too long for my taste. But that's just me.
