Standard Ford Alarm System
Old Sep 20, 2006 | 09:22 PM
MeanGene's Avatar
I have the Ford Alarm system, but I can't figure out how to test if it works. When armed I can pound on the windows and jump up and down on the bumper and nothing. Is this right, or should the alarm go off or at least beep once to warn the Perp?
Old Sep 20, 2006 | 09:47 PM
SilverScab 5.5's Avatar
The alarm only monitors door contacts and I believe the hood contact. So if anyone opens a door or the hood alarm will sound. Also if anyone turns on the ignition without a valid key alarm will sound. What you are talking about requires a shock sensor which the factory alarm does not have.
Old Sep 20, 2006 | 09:51 PM
BC_F150's Avatar
just to add to that just because you have a key fob to does not meen alarm alot of vehicals just have keyless entry
Old Sep 21, 2006 | 05:46 AM
PC Poppy's Avatar
Best way is to test it. Lock it up with the window down. Wait a minute or so and stick your hand inside and open the door with the handle. If all is quiet = no alarm.
Old Sep 21, 2006 | 08:11 AM
ONE04FX4's Avatar
Talking
and if it does not have one and you want an inexpensive one that works pretty good. i had an automate (made by DEI) put in. it comes with a siren and a shock sensor that uses the factory key fobs and has worked flawlessly.
Old Sep 30, 2006 | 11:48 PM
Operation:F-150's Avatar
The factory Ford alarm is a PATS system, which is a passive anti theft system. It does not have a shock sensor, it will only go off if the door or possibly hood and or liftgate if equiped is opened without turning the key in the drivers door lock cylinder or using the key fob. As a side note it will not go off if an unprogrammed key is used in the ignition it will just not start it would only crank.
Old Oct 1, 2006 | 01:29 AM
edisonrizon's Avatar
That's right if all is quiet that means you have only keyless entry
Old Oct 1, 2006 | 01:24 PM
MeanGene's Avatar
The alarm will go off if I open the door with the window down, also there is a little retangular box below the steering column that has a button on one end and a red light on the other.
Old Oct 1, 2006 | 01:37 PM
whitecrystal1's Avatar
Hey Meangene,
Sorry, I have to hijack your thread to ask a question. I tried to send you a message at first but I wasn't aloud.
You said you got the nav-traffic for your unit when you bought it. How is it working for you? Is that option worth the money. I remember you talking about getting it in your thread. I'm thinking about adding it to mine know. Just want to make sure it's worth the money. Thanks
Old Oct 1, 2006 | 03:03 PM
MeanGene's Avatar
Originally Posted by whitecrystal1
Hey Meangene,
I was considering getting the traffic unit, but I didn't get it yet. Most of the time I can get that info from the radio and reroute. I don't do that much driving in unfamiliar traffic areas.
Old Oct 1, 2006 | 03:13 PM
Darn, I was hoping you got and used it by now. I was going to use you as a Guinea pig. Thanks Meangene
Old Oct 15, 2006 | 04:18 PM
burntire's Avatar
What is this little box for?
It has a button on one end. Is that a valet switch?
I just picked up an F-150 an am trying to figure out all the features.
The dealer said they added a security system. The sticker only says keyless entry with scurilock.
Does it sound like I have something additional security wise?
Old Oct 15, 2006 | 07:05 PM
MeanGene's Avatar
Yes, it's there to add the additional security, which I think is only a engine start kill device. Meaning there are no additional sensors, but if someone were to force the hood or a door open the engine would be disabled and the alarm would go off. Depending on which alarm you have, you enable/disable the valet function by turning the ignition key to power on and off without starting 3 times within ten seconds.
Old Oct 16, 2006 | 03:41 AM
burntire's Avatar
Thanks for the info.
I will have to get under the dash and see what the model number is on the module.
Old Oct 16, 2006 | 09:18 PM
BMS's Avatar
BMS
Registered User
may not be a button on one end a red led on the other. Rather that button may be the **** on the shock sensor to adjust the sensitivity. I installed 2 factory ford alarm system (made by code alarm btw) and the shock module is about 1"x2" or 3" with a red LED and a small **** that sticks out. I can jump up and down on my truck right now and hit it and get nothing. I do get it if I close the tailgate though. I need to get up under there and adjust it to the right level, just keep getting sidetracked.
