2004 rear end stutter
Old Sep 12, 2006 | 01:32 PM
conway's Avatar
I searched! Too many ways to describe this issue, so searching is difficult. Thanks for your patience!
Can anyone explain, point me elsewhere, give me a fix, etc. for what feels like the rear end stuttering? Only on take off, and not all the time. maybe just after the truck Has sat a while or taking off in a turn. Not engine and not transmission. Almost like the rear tires are slipping.
Otherwise, the truck drives great.
Thanks in advance!
Old Sep 12, 2006 | 01:37 PM
kingfish51's Avatar
Do a search for shudder, and you will find a lot of info.
Old Sep 12, 2006 | 01:44 PM
Do you have a limited slip differential? I've been told that from time to time you may feel a slight shudder from of this type of rear end. I'm not sure if it would apply to your situation or not, but it's something to consider.
FWIW -- I have limited slip on my truck and have never noticed any unusual shudder from the unit.
Old Sep 12, 2006 | 01:46 PM
conway's Avatar
The search for 'shudder' helped. Thanks!
I hosestly don't know if I have LS. I just got my truck (used) a few weeks ago. It is my 4th F-150, but first FX4 and new body style, etc.
Anybody have a link or copy of the driveshaft TSB?
Old Sep 12, 2006 | 02:51 PM
kingfish51's Avatar
Honestly, if you have a limited slip rear, replace to diff fluid with the newly recommended weight (75w140) of gear oil and friction modifier. That is all I had to do to fix my shudder.
Look at the door jam sticker. If the rear axle code is a letter and a number (example H9), it is a limited slip.
Old Sep 12, 2006 | 05:16 PM
rtremaine's Avatar
known issue for 2004 models. Have dealer replace differential clutch pack with updated parts. Does it worse when it's cold when turning from a dead stop. no a big deal really, 3.5 hr job max.
Old Sep 12, 2006 | 05:23 PM
CHIA's Avatar
I have a 2005, and had the same thing, or what "sounds" like the same thing. Took my truck to the dealer, and they replaced the driveshaft....said it was not uncommon, and that the replacement shaft was larger diameter....covered under warranty, and I think there were also a service bulletin on it as well.
Typically happened when acclerating from a stop....felt like something was just not 100% connected...."shudder" was the best description.
CHIA
Old Sep 12, 2006 | 05:47 PM
conway's Avatar
Found 'em. (I think.)
Make : FORD Model : F150 Year : 2004
Manufacturer : FORD MOTOR COMPANY
Service Bulletin Num : 042420 Date of Bulletin: DEC 13, 2004
NHTSA Item Number: 10014100
Component: POWER TRAIN:AXLE ASSEMBLY
Summary:
LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR
VIBRATION DURING LOW SPEED TURNING MANEUVERS. *TT
Service Bulletin Num : 03198 Date of Bulletin: SEP 06, 2004
NHTSA Item Number: 10004037
Summary:
CHATTER, SHUDDER, A BINDING SENSATION, OR VIBRATION DURING LOW
SPEED TURNS ON VEHICLES EQUIPPED WITH THE 9.75 INCH OR 8.8 INCH LIMITED SLIP
REAR AXLE. *TT
Service Bulletin Num : 0416 Date of Bulletin: JAN 26, 2004
NHTSA Item Number: 10007359
Component: POWER TRAIN DRIVELINE
Summary:
DRIVELINE CLUNKING/GRUNTING NOISE OR SHUDDER SENSATION DURING
LIGHT TO MODERATE ACCELREATION AND/OR BRAKING. *TT
Service Bulletin Num : 17466 Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10007318
Summary:
CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION FROM LIMITED SLIP REAR
AXLE DURING LOW SPEED TURNS. *TT
Old Sep 15, 2006 | 08:36 PM
osbornk's Avatar
If the truck is out of warranty, I would not replace the clutch packs. One suggestion a couple of years ago was to go to an empty parking lot and make a bunch of figure 8s to make the clutches slip and thereby loosen them up. they said it works but I don't know myself.
Old Dec 26, 2008 | 09:39 PM
councillor's Avatar
What exactly is a TT mean ?
Old Dec 27, 2008 | 10:25 AM
garebel's Avatar
i just picked up a 2005 that did this on take off, i was being told all kind of fixes. i cornered one of the guys and he told me, $40 bucks for a single $80 for a split drive shaft, he took them off, lubed them put them back, fixed it
if i did not see it for myself i would have said bullshiat, i had other folks telling me rear end, blah blah blah....
it acted just like it, we would power brake it and the rear end would pop and jump just like the gears was slipping
save your money, ford put a small amount of lube and after it moves back and forth the lube gets moved so that there is a small amount of play.......blah blah
Old Dec 27, 2008 | 11:11 AM
Silver04f150's Avatar
holy 2yr old thread
Old Dec 27, 2008 | 11:17 AM
garebel's Avatar
Originally Posted by Silver04f150
holy 2yr old thread
very good reply, will read again
Old Dec 27, 2008 | 11:54 AM
councillor's Avatar
When we see "TT" ---- what does it means Tube Works or Twin-Turbos?
Old Dec 27, 2008 | 12:21 PM
Tbird69's Avatar
I believe "TT" is a code for the Ford techs.
