clearing tires
Old Sep 11, 2006 | 05:35 PM
jivins's Avatar
clearing tires
just wondering i have the 6 in fabtech lift and am running 315's and now after running those for a while can i fit anything larger than a 35 underneath without rubbing and if there will be rubbing can the fender be cut to make it clear.
Old Sep 11, 2006 | 06:37 PM
TonkaTruck33's Avatar
37's with 6in fabtech w/ dirtlogic coilovers.... 35's with regular 6in fabtech lift
Old Sep 13, 2006 | 08:55 AM
jivins's Avatar
so can i not buy the 900$ dirt logic coilovers and put on a 2.5 auto spring spacer and clear 37's
Old Sep 13, 2006 | 01:57 PM
BestNTx's Avatar
you can do a 3 inch body lift on top of your 6" fabtech and clear 37's, (if your a 4wd) or you could do the dl's with the spacer but you will screw up your cv angles and your ball joints will go out alot quicker...
Old Sep 13, 2006 | 04:06 PM
wandell's Avatar
I agree.
