LEVELING KIT with no rubbing/install issues? Everybody....
Old Sep 5, 2006 | 08:42 AM
sgerry's Avatar
so all,
what's the best leveling kit fot the money?
autospring-possible rubbing / install issues?
daystar?
Solid aluminum billet?
What does everyboy think.
Old Sep 5, 2006 | 08:51 AM
cvc14's Avatar
Ground Force 2" drop shackle.. No rubbing..
Old Sep 5, 2006 | 09:49 AM
sgerry's Avatar
That's the other option!!
Old Sep 5, 2006 | 09:53 AM
badcobra's Avatar
I bought this one. It was so easy, only took an hour to install on a lift. No rubbing and no issues whatsoever.
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
Old Sep 6, 2006 | 01:17 AM
mkinttrim's Avatar
Badcobra I have the same kit, mine was called EZ lift tho, but same product. Very east to install and no issies at all.
Old Sep 6, 2006 | 01:41 AM
EDGEonSTEROIDS's Avatar
I've got the 2 inch Autospring and have had it on for about 25K with no problems at all. Really easy to put on and I have plenty of coil/control arm clearance, even at full down travel. I checked my ball joints the other day and they're fine too.
Old Sep 6, 2006 | 01:42 AM
bryanfeelsgood's Avatar
I have the Autospring, no rubbing.
Old Sep 6, 2006 | 08:42 AM
sgerry's Avatar
good to know. We are here in germany with the AF and would not like to wait for weeks for replacement parts to come if the level messes with the front end.
Old Sep 6, 2006 | 08:54 AM
ChappyFX4's Avatar
Getting these delivered tomorrow from Summit. Cant wait to install.
Old Sep 6, 2006 | 09:57 AM
TXScrewZHD's Avatar
2" Revtek kit, 10K miles and no issues so far.
Old Sep 7, 2006 | 11:48 AM
conway's Avatar
On the Autospring - which actually makes the truck level? The 2 inch or 2.5 inch?
If the 2 inch works, it may produces less stress on things.
Old Sep 7, 2006 | 12:31 PM
TXScrewZHD's Avatar
I don't think there is an easy answer to your question. Every truck "sits" different and every truck will settle different after the install. 2.5 will get the nose in the air but depending on how your front end settels will determine the final stance.
I'd do a search, check out pics of the trucks with the kits and just see how they sit after the install. Everyone lists their mods so it should be easy to tell who has what.
Good luck.
Old Sep 7, 2006 | 01:12 PM
sgerry's Avatar
for the 2wd it seems that 2in works best.
Old Sep 7, 2006 | 06:27 PM
TNoff's Avatar
Those look cool. I wish I got some. I got the Daystars. Those urethane right? I didn't install them.
Old Sep 10, 2006 | 09:22 PM
Sandog53's Avatar
We use Ready Lift at work, and with a little secret fender mods unnoticeable to the untrained eye, we can get 35s under them with no rubbing.
