[pics] Of My Truck Finally!!!
Do you have this vibration? How much is it? Are you sure Rize makes it or do they just distribute it?
CANNONFX4
Do you have any vibes? But, yes Im still going to Black Sky. It will only be a couple more weeks, about middle of September!
CANNONFX4
yeah i get it.....i mean its not real bad but noticeable.....my passenger seat back bounces back and forth about 1/2 a inch in either direction (front to back)
you can feel it...
and the directions says "you can do the appropriate modifcation to the driveshaft or use Rize replacement shaft" so im guessing its theirs.
the modifcation mentioned is installing a CV joint on the transfer case side of the shaft. but its not required at all.
like i said its not a bad vibration but you knwo its their.
you can feel it...
It could be that you have a tire with bad road force or out of balance.
Are those rims hub centric? Meaning do they fit EXACTLY to the bolt pattern with no movement what so ever? If not, then that's most likely your problem.
In that case buy hub centric rings from Mazzi from your style truck and rim combination. They're about $25.
Then have the rims and tires HUB CENTRIC BALANCED with a Haweka style balancing adapter.
That will be the closest balance you'll ever have a chance of getting and should take away the vibe your describing. I know because I had the same symtoms and that was my fix for the new rims and tires (though no lift).
It'd be better to go down this route first then have to buy a new drive shaft. I read Rize's website and it talks about that drive shaft solution being mainly for trucks with extremely high torque (like a superduty truck).
Duke
Duke
Originally Posted by captain morgan8
I dont really like the front crossmember on the rize kits but I really want to go with an 8" lift. I was set on the 6" fabtech but I had not really seen much of the rize lifts so I really appreciate all the pictures. by the way your truck looks great. what are those, 18's and 38's?
Originally Posted by patshea098
well i prooved you wrong now didnt i haha
yeah thump.....rize makes a replacement driveshaft for our trucks. cause theres a vibartion around 70+ and a vibration in 4WD 40+
and it will last longer in better condition.
patman- haha its cool and thanks
ZR-900- i DO have to jump haha im going to save up for some kodiaks...
and roushlimited- i am EXTREMELY HAPPY!!!
still getting 17-18 going 50-60...though i use to get 20-23
How so ? My truck got 15mpg stock? Glad you finally got your lift kit. I wish I knew someone in the houston area who wanted a Fabtech. I'm trading my truck in. I would of basically given the kit away. 500 bucks.
i dont know if they are hub centric.....josiah do you know??
i never said it was the front driveshaft. but yeah when i take it in to get my new oil put in ill have them look at it....
and idk mabye gas where you are isnt very good. but i got 22 miles to the gallon stock going 50-60
k so how do io spin my tires......hold the brake down and gun the gas? i know sounds like a stupid question but in my head its im screwing my brakes up in the rear doing that.....
but yeah are the mazzi hulsk hub centric rims??
Originally Posted by GA FX4
Too bad you got OWNED 3 out of your 4 years! My brother just graduated from Tech last spring and I graduated from UGA in '04 so I'm used to the feud! The proof's on the scoreboard and we'll see again Nov. 25.
To set the record straight I "OWNED" you guys 2 out of my 3 years of playing...and yes i did actually play...(And yes the proof was on the scoreboard as you said, but we understand you couldnt read what it said either due to your blood alcohol content or more so due to the fact that you were attending UGA..LOL)gotta love the rivals, it cracks me up...I bet your bro is making more money than you too...lol
Although i will give you one thing, Athens was definately the place to go for women! Cant take that from ya...
. At least you picked the right truck, the only truck- FORD! I love messing with Techies! Its very easy to get in their head and they can't take a little friendly fire. Good luck this year! Hope Quentin doesn't hurt Reggie!
