3.5/5 djm kit for 4wd
Old Aug 24, 2006 | 06:26 PM
HawaiiFiveOh's Avatar
After doing some searching around here it looks like a couple people have the 2.5/4 drop, but I was looking to go with the 3.5/5. Just wondering if anybody else has used the setup on their 4wd truck and had any opinions or bad news.
Old Aug 24, 2006 | 07:05 PM
Marc Carpenter's Avatar
I used thier 2" drop lower control arms on my '04 4x4 Supercrew and like the results. The only drawback on using the 3.5 front is that you will have to shorten (cut) the tie rods to get it aligned properly which will cost you a few more $$$. The design of the DJM lower control arms is really very basic in that they just recess the lower shock mount deeper into the assembly which in turn lowers the entire front suspension. You will have to purchase new front shocks (struts) also. The stock ones on mine have just enough travel to work properly and maintain a good ride. The construction and workmanship is very good in my opinion...Good luck with it.....
