Need some help picking out a lift
I'd like to get a lift for my truck, but I don't want to go higher than ~4" inches. Now I was thinking about getting the Rancho kit, but I hear its as high as 6" kits w/ larger tires. I'd also be getting some larger wheels 33"-35" to fill in the space. What would you guys suggest? I'd like it to look a little bit more aggressive, with some larger tires. I'm not dead set on the 33"-35" tires either, just something more aggressive. Thanks for the help!
Originally Posted by Trooks2001
I would just get the 2.5" leveling kit to start you off. Its only around $100 and you can run some 33" tires.
Originally Posted by henkyjenky
What is it about the stock wheels that allow you to run 35's? The backspacing? Is it possible to get aftermarket wheels that match the stock specs?
stockers are 7.5" wide with 4.5" bs i believe...
not really a question of width, rather than how far your wheels stick out past the fenders... you need to be careful though because if you stick out too much, and are not lifted--when you turn you will hit the bushwackers - i had a thread running about this about a month ago probably- devin4x4 also has one going..his is a few days old, so if you flip through the pages you'd be in luck
J
if you look in my gallery you can see the truck on 33" toyo mt's i Upgraded this summer.
