Power Point Removal
Old Aug 21, 2006 | 09:15 AM
Toolcrib's Avatar
Power Point Removal
How do I remove the power point assembly out of the dash,the 4x4 **** was easy to figure out, but the power point I am not sure.Thanks.
Old Aug 22, 2006 | 11:26 PM
ericd's Avatar
Open the door and look inside the silver tube. On the right and left, you'll see two black squares of plastic, 180 deg from each other. After pulling the electrical plug, take a small flat blade screwdriver and press outward on one of the black squares. Put a little pressure on the center section from the rear while doing this to help hold the clip from re-engaging. Once you undo one side, press out the other. The center section should now slide towards you and out of the black plastic door assembly. Once this cylinder is out of the way, there are two plastic tabs on the remaining part that are holding it in. Just squeeze on both and it should pop right out.
I'll look at my workshop DVD and see if I can find a picture.
E...
