Closest Grounding Point
Old Aug 8, 2006 | 08:39 PM
patshea098's Avatar
k so where is the closest grounding point around the back seat 12V connection and air vents. i opened it up and was looking but couldnt find one...a flashlight probably would have been handy but yeah.
thanks
Old Aug 8, 2006 | 09:53 PM
GotBeer's Avatar
Run it straight down and screw it into the floor pan. What do you need to ground?
Old Aug 8, 2006 | 10:01 PM
ford2004F150's Avatar
thanks
There is a wire (black) ground on 12V acc by the vents....
Old Aug 8, 2006 | 10:10 PM
patshea098's Avatar
o there is? once again i couldnty see no flashligth and in my garage haha. i should have thought of that. can i jsut strip the ground partially and hook the ground i need to to it and then put electrical tape around it?
also im running a interior LED kit. another question is im running 2 of the kits, one for the front and one for the rear. can i hook both of them up to the same wires on the same 12V acc in the rear? thanks.
Old Aug 8, 2006 | 10:21 PM
Yes, the F-150's 12v powerpoint is capable of powering those add-ons just fine as LED's don't pull a big load. Mine powers an under body lighting kit and LEDs in the console. I would use wire nuts, V-taps, or soldering it and shrink wrapping.... don't just slap it on with wire tape.
As you know what goes around here.... once you are finished you have to post pics...
Old Aug 8, 2006 | 10:30 PM
InCuBuS's Avatar
or you could ground it to the metal frame of the dash. there was 2 things grounded like that when i took out my dash
Old Aug 8, 2006 | 11:30 PM
patshea098's Avatar
yeah thanks 2004f150 that helped. yeah im going to solder it. i forgot about shrink wrapping i have to go get some at home depot.
Old Aug 8, 2006 | 11:44 PM
-TXF150-'s Avatar
Any piece of metal...
Old Aug 9, 2006 | 12:16 AM
Tbird69's Avatar
THANK YOU
Old Aug 9, 2006 | 01:04 AM
patshea098's Avatar
well i know metal....but there was no metal to metal areas i could see...only metal to plastic.....
Old Aug 9, 2006 | 11:52 AM
Tbird69's Avatar
Then it's going to require some effort to get it done. You can tap the ground for the 12V outlet unless you need a heavier wire then run it through the console to the dash or under the carpet to the back seat and ground there.
Old Aug 9, 2006 | 12:20 PM
patshea098's Avatar
yeah its not a heavy wire at all.....these LEDS run off 12V so the grounding and the power wires are the same.
