Switch kit wiring questions
Old Jul 19, 2006 | 01:01 AM
Luke5181's Avatar
http://www.electric-life.com/images/...0schematic.pdf
Can someone look at this and help me out a bit?? I need to figure out why I have 2 fused wires and 1 extra blue/red wire. All the appropriate plugs are full and can someone explain what the headlight symbol means. I am wiring the ELECRIC LIFE 7 switch universal kit to (4) OEM Regulators. I attempted to put the rear window in today and all went well but you need power to make the window roll up and stay and I couldn't figure this schematic sheet out for nothing.
Old Jul 19, 2006 | 08:15 AM
OnBelay's Avatar
It appears the red/blue wire goes to dash illumination, so that the switch panel will light when the headlights/dash lights are on.
Without seeing which fused wires you have, or where any of the other wires are already attached, it's about impossible to know what else to tell you. You are saying "I've hooked up 6 wires, where do the other 2 go?"
Not to say "I told you so", but this is a lesson in why you plan out where the last wire goes before you splice the first one.
Old Jul 19, 2006 | 09:44 AM
HotBlue05SCREW's Avatar
what color wires do you have left?
Old Jul 19, 2006 | 10:07 AM
Luke5181's Avatar
I have 1 red/blue wire left that has a connector on it. I also have 2 of the fused red wires rather than 1. where is the illumination wire in the truck located by chance?? I also didn't splice anything, the wires are just plug and play and I have 1 left with every possible point filled
