autospring, crooked wheel
installed a set of 2" autosprings on my 06 f150 then went had an alignment done they showed me how far the front was off (quite a bit) but now since having it done my steering wheel is leaning to the left while the truck is straight. anyone else have this problem? should i take it back to the alignment shop?
I tried it three times.....I finally got tired of taking it in....bought a set of long handle wrenches from Harbor freight...and straightened it out myself.....you can do it if you're careful....I took a string to measure the tire alignment...front and back.....carefully loosened the lock nut on the arm....turned the adjustment the EXACT same amount....and believe me.....it doesn't take much....mine was about a 16th of a turn...but that's what it took to straighten the whell...then tightened everything up.....drove it.....and re-checked it with the string....no problems since.....and I drive about 110 miles every day on it....
