troyer ud ?
Old Jul 15, 2006 | 05:39 PM
otem's Avatar
troyer ud ?
i went to install my pullies from my 05 4.6 on my 06 5.4 and the water pump pully hits a little threaded stub out.what is it for and can i grind it down. anybody else have this problem.thanks
Old Jul 15, 2006 | 05:43 PM
blkscrew's Avatar
if you have a 3v 5.4 you may need to remove the mounting boss to the lower right of the water pump, the oversize pulley will come in contact with it. i removed an idler pulley and used a grinder to cut off the boss and grind it smooth. COVER THE ENGINE when you do this, the alum dust could be detrimental to many parts, esp the alternator, air intake, etc.
Old Jul 17, 2006 | 10:48 AM
khendrix2374's Avatar
Dont cut it off! Just grind it off enough on the side for the pully and belt to clear... dont cut it off.
