Fans finally in....A couple questions...
Originally Posted by ericd
Sorry for the novel, but I hope that answers your question.
E...
I'm pretty happy with the way everything turned out, with the exception of a bit of vibration from one of the fans. Get what you pay for I guess.
any further info on selling a few?? perhaps you could patent the shroud
Originally Posted by xplorgee
Im not a mechanic, but how does the core degrade with having fans mounted directly. I can see maybee damage caused by mounting the fans.
Maybe degrade wasn't the best wording. More like disintegrate. The vibration from the fans, when mounted with push pins through the fins, will eventually cause the fin to break down. After time, you have the entire weight of the fan resting on the .004" thick tubes, which is not a good thing.
My guess on the vibes is that the shroud needs a center reinforcment. With two fans spinning together, there's some crazy harmonics going on, and the large span of metal is amplifing them. It's wasn't constant either. There was a high freq. vibe for about 3 secs, 30 seconds of smooth, then the vibe again.
After watching the fans cycle for a while though, it's really not a concern. They don't run long enough to even hit full RPM, where the vibe happens.
E...
E...
Anybody work with metal a lot. It may be easier for them to access some tool to make the fan shroud. The only tool I have are a sledgehammer and a phillips screw driver. I dont think that will do. I asked the guy on ebay if he was ever thinking about selling the shrouds by themselves. He said no. That sucks.
Originally Posted by blkscrew
E....
I see your from New Eagle....where in Pa. is that?? I was born outside Williamsport in north central Pa.
"I have plans of offering the shroud separate in the future, but currently this full kit is all I have available..."
To be honest, I had no clue there would be this kind of interest in the sheet metal. I may have to push things along a little faster.
E...
Hmmm - I don't remember telling someone no. I think my form letter answer to everyone that asks about the shroud is:
E...
E...
My 16" fans are in the box on the shelf waiting, I'm in no hurry..
Still working on a Audio System..
I want them mounted to a Shroud, not to the Rad... besides, I think it would be less of a warrenty issure with Ford on E-fans if they aren't mounted to the cores on the Rad....
It's about 40 mins south of Pittsburgh...
E...
E...
Nice set up ,I would like to get in on this also
