Check this out
Originally Posted by -TXF150-
From what I understand, you have to do that in order to install a bodylift on these trucks right???
I believe the vents under the seats are nothing more than a cold air return. I could be wrong, but I think that is where the air is drawn from when you have your system set on recirculate. It makes sense, draw the air from the middle of the cab for optimal air movement.
dang thats alot even just 2 layers is more then enough, what brand did you use? it doesnt look like dynamat
i have been wanting to modify those rear vents to be cooled and heated seats, black leather isnt the most comfortable material in 110+* weather
I found I bolt under the carpet that I did not remove.... ford QC at its best. and I also loaded 5 cans of great stuff in the c-pillars and rear wall to stiffen the flex..... the floors resonant frequency is about 30hz now.
What size bolts do they use on the interior (if you have the sockets at hand) or are there too many to list. Any parts that were rather tricky (i.e. back seats)? Doin a great job, I would like to replace my carpet as well as install the body lift, only looks like 4 cab bolts to me.
Hey Styx - It's about time you get off your lazy butt!
I just got my other 9.0 today and my new PowerLines should be here in a day or 2, so I will be at it again this weekend. Still not sure if I want to tackle the headliner though. lol
