stepside billet hook delete blueprints
ok i have tried selling these when i first made them but no body wanted to pay so here are the specs of the hook deletes
this first drawing is mainly to show where the holes go and as marked with a pen the hole is at a 20* angle and then after drilled it needs to be counter sunk
then this pic shows all the correct dimensions of the final piece
and tell the machinist to round the edges
just take these to a machine shop and have them machine them for you
ok here are some more detailed pics of the piece its self
o and be sure to tell the machinist to fly cut the side of it that will be facing out, print all of these pics for him and these instructions he should have no problems but if you or the machinist have a question just ask
o one more thing you will need shorter bolts they are metric 5.95mm bolt about 1.25" long
o and almost forgot the most important thing i used 1/4" aluminum
also if you want you can have the machinist ball mill a design in it if you want, and ask him to polish it, they should have a polishing wheel on a bench grinder there
