?s about 04(lets try this again)
My truck is doing some strange things.
First my cig and power outlet on the dash went out (rear one is fine),
so i found the fuse and changed it out, so now the one under the radio works, but the other one to the right of the radio wont.
About the same time as all this my check engine light came on and it stayed on for two days then went off. I havent had time to have it checked , but i didnt know if the computer would read out what the problem was after the light is off.
Also my oil temp gauge and my battery gauge are reading a little high(to the right). They always ran straight up before.
Last my driver side, top two, window control buttons(driver and pass. door windows)wont light up.
Is any of this connected or does anyone have any ideas of what might be going on.
i searched and couldnt find anything specific, but if i did miss something a point in the right direction would be nice.
Thanks in advance.
Also i couldnt delete the other thread could a mod do it for me please.
Thanks in advance.
The window switch light issue you are having, I am having as well. I have popped my rear power points fuse several times and had to replace it. If you're a 4x4 check your 4x4 Solenoid and see if that fuse is popped (fuse #11 I believe). I have no other issues that relate to yours but that fuse is always popping. I still need to figure that out.
