put on black fx4 decals
Turned out pretty bad, I don't even wan to post a picture! First off, one of them is maybe a 1/16" off and I can see it from across the street, second I have air bubbles.... hate freakin bubbles. And I couldn't get them all out, even when I got one you can still see where it was. Up close they look like sh*t, and from a distance they look like they have little water drops on them. So.... then I decided I didn't like the 'offroad' and pulled that back off. Ready to pull it all off and throw 20$ bucks in the trash! Any ideas????
Did you use soap/water? I had a few air bubbles in mine even using soap/water and a tool for putting on decals to get the air bubbles out. But, you couldn't see them unless you were about 10" away from it.
Add it to your gallery, right click and hit properties, and copy the URL and add it your post using the [IMG] INSERT URL HERE [/IMG]
The Decal does look nice, but the air bubbles do look bad as you already know. I don't know what I do different, but anytime I put on decals, I use a hair dryer, and a credit card to smooth out the air bubbles. Seems to work for me
Originally Posted by masshol
Think I did it!!! Well hard to see in the pics, what do you think? I am not impressed, think I need professional
I dont like the actual decal design.
you should try to smooth them out with a hard plastic squeege thats made for installing decals. When you do it, take a small pin and pop all the air bubbles and then smooth them out. It might just do the trick.
Good luck
BREW
Good luck
BREW
Do what Brew said and you should be fine. When I installed the Roush rocker stripes on my other truck I still had a few of those. Poke em with a pin, push down to get the water out. It still might look a little bubbley but give it a day or so in the sun and they should go away
