Frame Plugs
Frame Plugs
I saw a while back someone on here had some covers or plugs for the open spots in the frame around the read wheel wells. can those be bought or is that a homemade idea?
Thanks guys, and as long as its dry when you install them it should keep the moisture out. a little silicone will make a good seal for ya. Plus I did a search and found that those parts of the frame have holes in them.
you should be able to find somethign like that at home depot, and like you said, use some silicone. if you're really picky, you can even find the soft plastic grommets at HD to fill all the other holes in the frame.
