Anyone know the Color code for wiring harness...
Old Jun 9, 2006 | 12:08 AM
yankeesfan81's Avatar
I am looking for the color codes for the speaker wires coming from factory wiring harness. I had a list of the colors but for some reason I cant find it... Basically I am trying to find out which color wires go to passenger drivers door speaker? The speaker has been cutting out once in a while when I go over a bump and it is starting to **** me off. But Im not sure which wire it is and I havent looked in the dash to test out which one it is..
Thanks ahead of time..
Matt
Old Jun 9, 2006 | 10:19 AM
FX4ME2's Avatar
Matt
white/lt green, dk green/orange
Old Jun 9, 2006 | 09:35 PM
thank you very much.... that saves me from going out and checking each wire...
Old Jun 12, 2006 | 12:22 PM
Guigster's Avatar
I have sort of the same problem! When I installed my PIE, everything worked fine. Then when I put the radio back, I had no sound from my right front speaker. I had to mess with the wires to position it so it wouldn't cut out. Now I get a little static sound sometimes when I go over a big bump. Only really hear it on the talk stations though. Is there an easy way to fix a wire inside that harness?
Old Jun 26, 2006 | 02:47 PM
Guigster's Avatar
Bump...
Anyone know of an easy, inexpensive way to fix a bad connection in a wiring harness?
