? for Bill at Edge Products
Is anyone working on a fix for the transmission shudder in O/D running level 3? I've tried everything but nothing seems to work or even make it somewhat better. Adjusted shift firmness + & -, adjusted standard shift points + & -, etc. but no fix. I've called tech support several times and even gave my hex code but they said that they haven't come across this situation.
I'm just getting impatient on a fix. I've had the evolution since Feb. Lately I've been running level 2 with no problems w/93 octane and +3 timing but it's just not as fun as level 3. The truck puuls so much harder in level 3 and has alot better throttle response. Please help!!!
Does it feel like the engine is missing when running lvl 3? That is the problem I have. Called them multiple times, but they want me to send my unit it. I know it isnt the unit itself, its their program.
Guest
Posts: n/a
Originally Posted by GotBeer
Does it feel like the engine is missing when running lvl 3? That is the problem I have. Called them multiple times, but they want me to send my unit it. I know it isnt the unit itself, its thier program.
No it's not missing. When you are going down the road at about 55 and you go over a bridge or a bump the tranny shudders or bucks. The only thing I can think of is that the throttle response is so touchy in level 3 that the smallest input on the accel. is making it do this.
My timing is only +1 to +1.5 running 93 octane and 1.40 WOT fuel. My hex code is RXCM5E4. The problem may be linked to a specific hex code. That may be why some are having the problem and some aren't.
jim
Originally Posted by jims94vmx
maybe a mistype here, that is what i responded to thinking you are a little much in the timing...? just a thought was all.....
jim
jim
I could be wrong but mine clunks and bucks at light throttle around 50 and I always just though it was the torque converter locking and unlocking and it is noticable because of the higer line pressure due to the edge settings. It clunks letting off then clunks/bucks applying throttle after just letting off.
Yeah, mine does that too. Wonder if softening the shift pressures will stop the clunking.
