Let's settle this once & for all: Front diff's are NOT LSD!!!
I'm sorry, but lately I've seen alot of debate about whether or not front differentials on F150's are LSD or open. Well I just went out and checked mine, and it definately does not have a LSD front diff (it's a 4x2)
Seriously, even though it doesn't pertain to me, I still had to check out reliable sources, so I pulled up the FoMoCo service manual for our trucks. Here's what I found:
I know this does not come out right and say it is not LSD, but if you notice the specs for the rear diff, it mentions the Friction Modifier. But nowhere in the specs for the front diff does it say anything about Friction Modifier. In addition, I thoroughly looked through all pages in the manual about front and rear diffs; there are lots of pictures of the diffs being torn down, but nowhere is there any reference to the front ever being LSD. For example, for the rear diff service procedure, there are actually 2 different procedures (one for LSD and one for non-LSD). But for the front, there is just 1 procedure (obviously for non-LSD, as all front diffs are).
Anyway, just one of my pet peeves lately, seeing this debated soo much with so much certainly by both sides...
Originally Posted by Service manual for REAR DIFF
Lubricant Specification Capacity
Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant XY-75W140-QL (US); CXY-75W140-1L (Canada) WSL-M2C192-A 2.60 liters (5.5 pints) (6-14 mm [1/4-9/16 in] below the bottom of the filler hole)
Additive Friction Modifier XL-3 (US); CXL-3 (Canada) EST-M2C118-A 4 ounces to be installed before axle lubricant
Originally Posted by Service manual for FRONT DIFF
Item Specification
Front Axle Capacity
Motorcraft SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL WSP-M2C197-A
1.70 liters (3.6 pints) (9.56 mm [0.38 in] below the bottom of the filler hole)
Front Axle Capacity
I haven't seen any of the debates that you mention, but this one is easy to settle. The following method will work for any vehicle axle, front or rear.
Jack up the axle in question so both tires (L & R) are off the ground and rotate one of the tires by hand. If the tire on the opposite side of the same axle rotates in the same direction as the one you are manually turning then it means you have a limited slip differential. If the opposite tire turns in the opposite direction it means that you have an open differential.
But you are correct. No primary RWD Ford vehicles have any type of traction assist differential in the front axle.
Originally Posted by cesardajr
Is it worth getting a front limited slip?? will it help or hurt off road action???
Actually, I had the option of ordering both front and rear Limited Slip on an F-150 - but that was back when I ordered my brand new 1995 F-150. (I just got the rear.) A friend of mine had a 1980's vintage F-250 with factory front and read LDS's and used it as a (snow) plow truck. He said it was the most bizzare handling truck in the snow he ever drove.
You do not want to add a lock to our front diff's unless it is an air locker. Because if we have a locker front diff and the IWE's fail and engage it will be a p.i.t.a to steer with a solid front end, just ask anyone who has drive 4wd with lockers front and rear it doesn't steer that great.
