rear axle seals leaking again at 85000km?
one quick question for guys that have had their rear axleseals leak had it needed axles or could they get away with just seals?
Ryan
Ryan
I've always replaced the axle bearings with the seals, just 'cause I'm right there and got everything else torn down. Inspect the axle closely for any pitting of the surface where the bearing rides. And inspect the differential vent to be sure it's not plugged, allowing excessive pressure to build within the housing and compromise seals.
thanks
they replaced the first set under warranty and replaced the axles with the seals so this next time i'll be pulling it apart and was what the chance that the axle would be wore or pitted.
Ryan
Ryan
