WANTED: Pic's Of Factory 20's With Only A Leveling Kit
Originally Posted by MDCurtis
Cool, did you get them on ebay?
TXCobra,
My AAL arrived last week and the AS2" should be here the following week. I am going to try and get them installed on June 12th. THen off to the Tire shop!!!!
I am going to have them try a 325/60/20 on the EOM 20's. My plan is to have the tires on by the end of June!
Nebraska
Nebraska
If you try some of the big truck tire centers they might be able to balance your tires with something other then the stick on tire weights. I know i had a set of 31's on a 78 bronco that had powder in them for balancing but what i found was the moisture made the powder ball up and not work so well, but i have heard that now they had glass beads that they can put in and balance the tires with better, it flows therefore allows for a constant changing balance which is the problem with larger tires as you drive down the road and wear them out
Originally Posted by Nebraska
TXCobra,
Nebraska
Nebraska
Originally Posted by Indiana-red4x4
Yes, I put them on the truck today. I am going to switch the white letters next week sometime. I really like the look of them. I have the FX4 center caps and I want to get a set of the Chrome center caps.
thanks,
