2006 20" Pirelli Scorpion Specs
Old May 14, 2006 | 03:37 PM
txnole's Avatar
I was able to grab some 2006 20" takeoffs for my truck and I'm wondering what the factory "recommended" tire pressure is for the 275/55/20 Pirelli Scorpions off the driver's door?
Any 06 owners have a minute to relay the spec? Thanks!
Old May 14, 2006 | 05:13 PM
NASSTY's Avatar
It says on the tire "Max pressure 44lb".
So if I wasn't hauling a full load I would run about 35-36lbs.
Old May 14, 2006 | 05:19 PM
txnole's Avatar
I've been running 36, but I'm still curious to know what the Front/Rear recommendations are.
Old May 14, 2006 | 05:24 PM
26point2's Avatar
According to the door sticker on my '06 FX4 scab it's 35psi cold...for both front and rear..
R/
Craig
Old May 14, 2006 | 05:34 PM
erick_e's Avatar
R/
Craig
Correct you are; 35 PSI is what is recommended.
Old May 14, 2006 | 09:36 PM
XTRUKY's Avatar
recommended pressure is CRAP
go by the pressure on the tire for MAXIMUM mileage.
Door pressure recommendation is for Ford's image.
Old May 14, 2006 | 09:49 PM
Indiana-red4x4's Avatar
So what is the correct pressure?
Old May 29, 2006 | 04:34 AM
04silverscrewfx's Avatar
anyone else on this?? is 35 psi the way to go??
Old May 30, 2006 | 06:17 PM
kitchenboy's Avatar
On my 06 Lariat screw there are two stickers with pressures on them, one on the door and one on the center pillar between the front and back door. They both say 35psi, but the tires say 44psi max. When I got the truck I checked the pressure and it was over 50psi. I think they jack them up for shipping purposes. I lowered them down to 35, and the do sometimes look a little low. Maybe I shoul go a few pounds higher.
Old May 30, 2006 | 06:25 PM
bushtree's Avatar
the tire says 44 with is what they need to be at to carry the max load they are rated for. Ford says 35PSI as that helps to give a better ride. I would stick with 35 as it will give you a softer ride.
Old May 30, 2006 | 08:57 PM
Brilac's Avatar
I run 40 psi in mine.
