33" tires for 20's????
Old May 10, 2006 | 08:58 AM
Nebraska's Avatar
I am looking for a good tire for the factory 20's. I would like to stay around the 33" so it will still fit in the garage! I do 80-90% highway driving, but want a more aggressive look than the stock tires! I have found the following:
BFG KO 285/55/20
Toyo MT 33/12.5/20
Nitto 305/55/20
Xtreme AT 33/12.5/20
Am I missing any? I plan on adding a AS 2" and an AAL to the rear. Which do you think would look better?
Thanks,
Nebraska
Old May 10, 2006 | 01:55 PM
sirshan's Avatar
Irok 33/13.50 20. Pretty aggresive tires...like a Toyo MT.
Looks good on Factory 20's. A member here has it on his ride with the same setup youre running.
Old May 10, 2006 | 03:15 PM
ThumperMX113's Avatar
Iroks have terrible wear for the most part, especially considering how heavy these trucks are. . I'd stick with the Toyos or BFGs.
Old May 10, 2006 | 03:40 PM
Nebraska's Avatar
Since I spend most of my time on the road I am leaning towards the BFG KO's, but wish they made a little bigger size. I know they make a 325/60/20, but that is almost a 36" tire (35.5)!! I still want decent mileage and be able to fit in the garage!! I may just not put the AS 2" and AAL on and get the 285/55/20's?? Still pondering!!!
Thanks,
Nebraska
Old May 10, 2006 | 04:03 PM
wandell's Avatar
You might also consider the Mickey Thompson Baja Radial ATZ and MTZ and the **** Cepek Radial FC II.
Old May 10, 2006 | 09:41 PM
Nico's Avatar
Goodyear AT-S, 275/65-20 LR-E
Its the stock Harley F-Super Duty tire. Its a 10 ply so it can take some serous weight. Its about 34x11 so its alittle narrow (same as the stock pirelli) but its the right height. Should be under $300 a tire, and will go 50,000 miles, that in its self is worth haveing a tire thats not a inch wider.
Old May 10, 2006 | 09:46 PM
N2 TRBL's Avatar
Old May 12, 2006 | 03:11 AM
2000F150HD's Avatar
I would go with the toyo M/T's if you can find/afford them. You could also go with Nitto or Swampers... but both will be worse on the road than the Toyo's.
I do love my Iroks though. They are on factory 20" wheels...
-stephen
Old May 12, 2006 | 06:21 AM
Cincy F150's Avatar
The Nitto's run real smooth on the highway and are nice and quiet but can still sling some mud when needed.
Old May 12, 2006 | 09:56 AM
Nebraska's Avatar
Thanks guys!! I have thought of the Goodyear AT's, a local shop will charge 270 each installed. Not bad, I am a little worried about how narrow they are. Do you think they would look like bicycle tires??
Thanks,
Nebraska
Old May 12, 2006 | 09:58 AM
Nebraska's Avatar
Cincy F150,
How much did your mileage change after the As and tires?
Thanks,
Nebraska
Old May 12, 2006 | 11:51 AM
BigBlackFX4's Avatar
Thanks,
Nebraska
The 33x1250x20 Toyo MT's are tough to get. I ordered them in February and am still waiting. Supposed to be today or early next week. You can get them for a comparable price. I beat up all the local guys and got them down to $275 each. Now I just have to find wheels. I have picked out 4 different styles, #1 was way too much $, #2 & #3 were discontinued, and #4 is now backordered 3 -4 more weeks. Just my luck.
Old May 12, 2006 | 12:10 PM
Cincy F150's Avatar
I was getting 18.5 and now it is around 17 with 60 highway/40city driving. I am running the 3.55's and this made the gearing a little tall so on a hill it kicks out of lockup more often. With your 3.73's and 33's, you will end up with about a 3.55 ratio.
Old May 12, 2006 | 02:59 PM
Nebraska's Avatar
CrAz3D,
Do they come in a 33/15.5/20??? If so very nice!!!
Nebraska
Old May 12, 2006 | 04:48 PM
Nebraska's Avatar
I just ordered the Skyjacker AAL for $113.25 delivered!!! I am going to try and order the AS 2" this weekend. I also found ou that goodyear makes a 305/60/20 (34.4/12.5) in the new silent armor tire. I have called a couple of shops to get pricing!!!
Nebraska
