Lights turn on when Doors unlocked
When I unlock my truck when it is dark or nearly dark the headlights turn on. Is there any way to turn that off so the light won't come on when I unlock the truck?
I believe ther is a way to do it listed in the manual. You can download a fre manual in PDF format from www.motorcraftservice.com in the owners section.
Thanks I think I found how to do it. I will try when I get home. I am wanting to turn that feature off because I am planning on doing an HID retro and don't want the bulbs to ingnite and turn off like that.
Yup, turned mine off when I went HID. If HID Bulbs werent so bank, its definately nice lighting up a parking lot or something when you disable.
Originally Posted by 02SuperCrew4X
I believe that if your lights are in the Auto position, they will turn on when you unlock the truck. Check that first...
Originally Posted by cobraman302
Yep, what he said. When its on automatic and its dark outside they will light up when you unlock the truck I believe.
Ok I got home and checked out my truck autolamp delay on the message center (I have a lariat) and I set autolamp delay to 0 sec...but they still light up when I unlock the door. Am I in the wrong place to turn it off? And my headlight switch is in the off position
