06 F150 - Won't go into 4X4 Low?
I can't get the truck to shift into 4x4 low. Both lights (Low and High) come on when the truck first starts up, but I can never get the light to come on (or it to engage) into 4x4 Low. When I am in High and switch to Low, sometimes the High light stays on. Only 1800 miles on her, but it sounds like I am going to the dealer and I hate that more than anything. Any ideas?
This is going to sound completely crazy, but when I tried this earlier today, I was on a very steep boat ramp with it stopped and in neutral (brake on obviously)...I could not make it go into 4WD Low. I was just out messing with it again (now on level ground) and it will go into low. ??
Originally Posted by red_candle
I prefer manual transfer cases to those electronic ones. At least on my 2005 XLT I can yank on the lever to put it into the mode/range I want.
How long does it take for 4 low to engage? I was playing with mine the other day and thought 4 low didn't work. I had it in 4 High, stopped and put it in neutral, set the switch to 4 low and the 4 high light went out but the 4 low light never came on and I didn't hear any noises like I expected. I put it back to 2 hi and 4 low light came on! No matter what I tried I could only get 4 low in the 2H position and 2 wheel in the 4 low position. I turned the truck off and started it back up with the switch in 2 Hi. The truck was in 4 low. After flipping the switch all over the place while in Park, neutral, drive and reverse I finally got things back to normal. I drove it home and messed around with it in my driveway. Everything worked as expected but I noticed if going into 4 low it takes about 15-20 seconds to engage. If you move the switch from 4 low before it actually engages things get messed up. Is something wrong here or I just need to have paitience when put it into 4 Low?
If you were just looking for some extra traction on the boat ramp, 4wd high should do just fine.
Originally Posted by lrhogfan
Not that it matters, but I don't understand why you would need 4wd low on a boat ramp. I haven't spent a lot of time with my 05 F150 in 4wd low, but I can tell you that most of the trucks that I have owned before like to have a little bit of room or slippage before they engage into 4wd low.
The brake pedal has to be pushed in as well as be in nuetral and come to a complete stop.
I HATE pushbutton 4x4. I like to be able to feel the transfer case engaging. That's the main thing I miss about my old Tahoe sport.Grim
Gotta do the stopped and neutral thing, i also give it a few seconds.... seems like it takes forever, but you can hear the gears engage if you don't when you first move it will and will hard, make a clunck, i like to use my 4 low at the boat ramp as well just so that it gets used once and awhile as well as i like to also use the parking brake then to for the same reason, keeps things moving and lubed.
just my .02
just my .02
