Shocks, AS, Tires
Shocks, AS, Tires
I would like to get a set of bilstein front lift shocks. These are supposed to lift the front end 0 to 2". Part number front BE5-C298-H0 rear BE5-C300-H0. Would this be able to replace the 2"AS. And would rubbing occur with 35" tires. I have read the 50 or 60 posts on rubbing and there has been no definate answer.
Definate answer is that 35/12.5/18 will rub at full lock on factory rims. You will need to trim the inner fenderwell for aftermarket rims with more backspacing. If you go aftermarket and do the trimming you will have no rubbing issues.
