Pioneer Low Pro Sub
Pioneer Low Pro Sub
I also posted this in the sub forum, but everyone here may also have interest. If you have a response please post in the sub forum. thanks.
Has anyone tried to heard the Pioneer Low Profile Sub. There are showing a mounting depth of roughly 4" for a 12" sub. Sounds like a perfect fit for a screw!!
Features
Size 12"
Woofer Cone Material IMPP Composite Cone
Surround 3-Layer Fiber Woven Radial
Voice Coil 4 Layer, Long Voice Coil
Voice Coil Bobbin Glass Cloth
Projected Pole Yoke with Vented Pole
Magnet Construction Strontium
Basket Design Cast Aluminum Basket with Fin-Shaped Design
Gasket Rubber
Wire Terminals Spring Compression
Specifications
Watts MAX. Music Power 1400W
Watts Nominal Power Handling 350W
Frequency Response 18-1,000Hz
Sensitivity 88dB
Ohm Rating 4
Recommended Enclosure 0.5-1.0Cubic Feet
Features
Size 12"
Gasket Rubber
Specifications
Sensitivity 88dB
Ohm Rating 4
