3v manifold modded webpage.
Old Apr 24, 2006 | 10:40 PM
assasinator's Avatar
http://home.att.net/~bill.fisher/index2.htm
this is a rough draft. the philosophy is to remove all restrictions. i will be trying different configs over the next few months. such as partitions between opposite banks. a thin wall to seperate them without restricting etc. you will notice a huge increase in volume. it all helps top end. your vct should minimize the low end losses. -bill
Old Apr 25, 2006 | 01:12 AM
HIDPLANET's Avatar
FYI nobody can see the images on that website.
It is sourcing images on YOUR computers hard drive and it needs to be changed to source the images on a web host.
Old Apr 25, 2006 | 01:53 AM
texxx150's Avatar
I see them just fine
Old Apr 25, 2006 | 02:46 AM
Kool Aid's Avatar
This is the address of the first picture.......
file:///C:/Documents%20and%20Settings/Customer/My%20Documents/My%20Webs/IMG_2713.JPG
How is it you can see his hard drive?
Old Apr 25, 2006 | 02:48 AM
Josiah's Avatar
HIDplanet is right, please fix as I'm greatly interested.
Old Apr 25, 2006 | 09:45 PM
sorry about that. i did it in a hurry.
Old Apr 25, 2006 | 09:49 PM
baja150's Avatar
I could see them fine.
Old Nov 10, 2006 | 06:14 PM
i have started version number 2.
the page describes the changes.
stock plenum, with full length tapered runners that hold a lot of volume.
Old Nov 10, 2006 | 08:50 PM
ONE04FX4's Avatar
Talking
do you have a pic of the plates that you said you removed for the 7hp.
Old Nov 10, 2006 | 11:13 PM
i will take one tomorrow.
if you pull the intake, they are covering the ports.
4.6 3v guys have plates the can purchase called cmcc delete plates. we don't need them. free 7hp. check it out at
http://www.modularfords.com
in the 2005+ mustang section. i'm here to tell you i could feel the change especially above 4000 when i pulled them.
those of you that have topped out bolt on HP can add a little more.
Old Nov 10, 2006 | 11:48 PM
ONE04FX4's Avatar
Talking
ok so will we need tuning for it to work properly? is there a way to keep the engine light from coming on or just leave it plugged in and just remove the rods. and the intake will just bolt right back on right?
Old Nov 11, 2006 | 10:20 PM
ONE04FX4's Avatar
bump for info
Old Nov 12, 2006 | 08:23 PM
ONE04FX4's Avatar
bump!!!!!
Old Nov 19, 2006 | 07:57 PM
Josiah's Avatar
secrets dont' make friends, assassinator
Old Nov 19, 2006 | 08:18 PM
sorry for the delay answering.
yes just remove the plates and square rods, silicone it and then reconnect the motor to the computer. it will not know the difference.
the tune is a simple mixture adjustment using the controller of your choice and a dyno. or datalog it and adjust.
