How to: Laptop Desk
Old Apr 15, 2006 | 05:48 PM
bniedert's Avatar
How to: Laptop Desk
Some of you have asked about my laptop desk so I figured I would take a few pics and show you what it is and how I did it.
It's built with 3/4" black pipe. I used nipples, unions and 90s to configure. The unions allow for angle adjustment and quick removal.
Here it is. My lap top is mounted in a position just off my console. I use the laptop for GPS (Delorme MapNGo). There are other things I do with it but I am not willing to admit it here.
Here is the base which uses the front left passenger seat bolt to secure. The base is steel plate with a flange bolted to it. A union is mounted to the base to allow removal. Full seat operation is acheived with the mount removed to this point.
A 12" nipple and other fittings complete the framework.
The laptop mounts on a platform made from laminating two 1/8" sheets of acrylic. I used some aluminum angle to provide a lip.
I placed a sheet of non-slip shelf lining on top and velcro strapped the laptop on. See figure 1 above.
By varying the type and length of piping used, you can put your laptop in just about any location. You can paint the pipe and fittings for a cleaner look. My pc power supply plugs into the back of the console and sits under the passenger seat.
Good Luck.
Old Apr 15, 2006 | 06:24 PM
Josiah's Avatar
where did you mount the gps antennae.
Old Apr 15, 2006 | 06:33 PM
bniedert's Avatar
I throw it on the dashboard pad. Works fine there. It's in the glove box when not in use.
Old Apr 15, 2006 | 06:38 PM
GordoPanocho's Avatar
Registered User
Interesting build. While I'm all for the satisfaction of doing it myself (sometimes), I'd probably have to just buy the Jotto Laptop Auto Desk.
http://www.jottodesk.net/ford-jotto-...desk-f1200.htm
Here's an old thread with another user's design, etc.
https://www.f150online.com/forums/sh...d.php?t=142347
