TSB Reflash
Old Apr 12, 2006 | 10:37 PM
JForestZ34's Avatar
TSB Reflash
Hey guys just looking for the TSB# for the reflash. I have a 05 f-150 and I think it qualifies for the reflash. It was built in Oct 04. Is mine good to go with the reflash. If someone could post the TSB# I could bring it with me when I bring it in for the first oil change. Thanks
James
Old Apr 12, 2006 | 11:57 PM
JerryK's Avatar
TSB 05-10-2, Driveability Conditions
TSB 05-19-01 Lag/High Idle cold, stumble at 40mph
Old Apr 13, 2006 | 08:02 AM
JForestZ34's Avatar
Thanks for the numbers. Is there a website I could print this TSB out on so they don't give me crap over it. Thanks
James
Old Apr 13, 2006 | 10:04 AM
JerryK's Avatar
I didn't even need the TSB numbers, I just used those words and complained that it had a lag when I first hit the gas, when it was cold and I started it the idle raced to 2000+ making it unsafe to drop it in drive, and it would get confused sometimes around 40 or 45mph and couldn't decide what gear or would drop real rough into a gear at that speed. That was it, they never needed the numbers.
Truck does drive better. I'd describe my truck before as a 3 speed vacuum cleaner: You start off from a stop and its in low, then around 3000rpm it would be like a switch and it would pull a little harder as if the vacuum cleaner was switched to medium, then it switched to high at 4000rpm. Now full power is in by 3600rpm or so and a little more of the power is available from 2000 to 3600. It also doesn't get some pre-ignition knock on 87 octane but that could be too early to really tell yet, I have a whopping 60 miles on the flash so far..
