Keyless entry with keypad questions
Old Apr 6, 2006 | 11:51 PM
deerfeedrb's Avatar
I used the search feature and still have some questions.
My goal is to install keyless entry with a keypad to my XL which has no power locks. An alarm is not necessary, I only want keyless for convenience. I saw Chris Adams used a PowerCode system to achieve this. If I purchase this and a wireless keypad, will I need to purchase/create an additional harness? Are there aftermarket keyless entry systems that have a keypad that doesn’t require drilling? Is there a simpler way to do what I want?
Old Apr 7, 2006 | 07:45 PM
deerfeedrb's Avatar
Well I purchased this, I decided to pay the extra $25 for the alarm. I hope it works.
Link
Old Apr 7, 2006 | 08:51 PM
ChrisAdams's Avatar
http://www.autotrucktoys.com/escape/...SVvxEfIbGyS4F7
is what some sell that for.
Did you download the PDF file from
http://www.gemsen.com/ford/
That gives you great detailed instructions.
If you do not have power door locks you will need to add power actuators and two relays.
To put in a keyless pad like I did is sorta hard. E-mail me and I can give you info, but you may not like it... Took all afternoon, 15 bucks worth of wrecking yard parts and a stock keypad handle, plus some time with a schematic.
Chris
Old Apr 7, 2006 | 09:00 PM
deerfeedrb's Avatar
I appreciate your help again Chris. I decided that I will install the stick on keypad because it sounded like a lot of work to integrate the keypad handle. If I run into problems, you’ll be the first I contact. Was the kit I ordered similar to the one you got?
Old Apr 7, 2006 | 09:22 PM
ChrisAdams's Avatar
Bad news. The stick on pad did NOT work with my Powercode unit.
It was not quite what you got, it is a powercode deluxe.
I bought the Powercode and the stickon after being assured by dealers, posters, vendors that they would work together.
They did not.
I then went a different way, putting on the stock door handle and rewiring it to work independent of the alarm.
If this is truly the original Ford part it may work. Wish I could be more helpful.
Chris
Old Apr 7, 2006 | 09:41 PM
deerfeedrb's Avatar
grr... sounds like the same thing will happen to me. The dealer told me that the stickon would work. I hope it works since it has the ford sticker on it. I'll keep my fingers crossed.
